Thermostat issue
24 Feb 2021
Hi All.
We have Greenstar RI boiler for pressurized system. Our thermostat is British Gas RS1.
Yesterday I have noticed boiler is constantly on. Today I have reduced the thermostat to lowest to test it. Despite thermostat is on lowest, boiler is still on.
Do you think issue is the boiler thermostat or British Gas RS1? I am a keen DIYer. Do you think it will be an easy task for me to replace the thermostat - after turning all electricity off? Which thermostat do you recommend?
When I turn off the programmer (British Gas Model UP1) boiler turns off. So I think issue is isolated to thermostat.
Also if the issue is the thermostat, can I take the front panel off and replace with front panel from Drayton RTS1 1-Channel Wired Room Thermostat , without any changes on the back connector panel?
Yes it would be a straight swap.
But as earlier...
Remove the RS1 from its backplate (avoid touching the live contacts!).
Does the C/H turn off?
To check that it really is the thermostat!
When I remove the RS1 from the back plate, C/H turns off.
So straight replacement for RTS1 then. Correct?
Yes.
... Or for a temporary solution, you could try giving the RS1 a couple of sharp taps with the handle of a screwdriver - it may free up a stuck contact, but it will definitely help to relieve any frustration! ;)
Great. Thanks for the help.
Little tap always might work. Even Han Solo gives a tap to Millennium Falcon. :D
