Thermostat Replacement
13 Feb 2014
Cheshire
Hello,
I'm looking to replace an old analogue central heating thermostat with a digital one.
I was wondering if somebody more experienced would help me with the wiring?
Where would the wires from the old one go into the new one? I've researched it for a couple of hours and have a rough idea, but it'd be nice to have some confirmation.
My main concern are the N1 & L1 load wires.
1. Old thermostat wiring diagram
http://www.montel-css.co.uk/SupOther/Resources/honeywellt6360wi.jpeg
2. Old thermostat actual wiring
http://www.montel-css.co.uk/SupOther/Resources/dsc02209.jpeg
3. Old thermostat installation guide
http://www.honeywelluk.com/Documents/Installation-Guide/pdf/1151.pdf
4. New thermostat terminals
http://imgs.inkfrog.com/pix/Eglobal/HT0000601_9.jpg
5. New thermostat installation guide
http://milantrend.com/BYC08.pdf
Thank you,
Kamil
Do you have an existing timer? If so, set it so Heating is permanently ON.
Connect as follows:
Red (from T1) to L
Blue (from T2) to N
Yellow (from T3) to L1
There is no need to connect anything to N1
The green/yellow wire should not be connected, but made safe; e.g in a terminal block hidden behind the new stat.
