Thermostat Wiring Puzzle
live in L common
switch live in L1
the other two are neutral and earth not needed.
you have to check with a multi meter.
as people use different colour wires and don't label them properly.
so check for a live on one when the programmer heating on.
switch live
neutral, earth.
earth, neutral not needed on new one.
That's brilliant. Thank you for your help - I will try and find someone with a meter I can borrow.
I am in serious danger of becoming competent at this stuff!
Competent or not, be mindful of what you do with the unused Earth and Neutral wires. If they join it could trip an RCD in the consumer unit, and in any case, all unused wires should be either terminated safely (ie, connected to dummy terminals) or disconnected at the other end. Good practice to leave earth wire connected as it protects the cable.
