Thermostat
27 Feb 2015
Durham
Can anyone tell me if a Siemens Rde 20.1 is compatible with a baxi duo tech combi 33. Thanks
Depends what you call compatible.
It will work - if you already have a wired room thermostat and want to retain this location.
Thanks a lot. That's what I meant. It's already wired in and I don't want to change it unless I have to. Cheers.
If your present thermostat uses a Neutral wire then this must be terminated separately in a connector block and not connected to anything.
The diagram in the RDE instructions is misleading and would create a short circuit if followed.
