only getting luke-warm water even when set to max from Bristan Sonique thermo valve. It's a single lever operated valve. Cartridge only recently installed in last 4 weeks replacing one that would not turn. Runs off a Worcester Bosch Greenstar 37 cdi and woked fine up until 24 hours ago. Bristan rep suggests checking cold water pressure by running shower at full temp, then running cold water from basin to check in any fluctuation and then flushing WC.
Any thoughts? Just seems a little odd that the temperature has failed so quickly.
