I have been trying to get two radiators working for what seems like an age now. A bathroom one (upstairs) and the hallway one (downstairs).
I have a total of 5 radiators in my house, bathroom, bedroom 1 and bedroom 2 (all upstairs). A living room one and a hallway one (downstairs).
I fitted a thermostatic valve on both bedroom radiators about 2 years ago and that's all been fine. So I fitted one on the bathroom one about 6 or 8 months ago and since then, the radiator has never worked properly, it never gets any more than very slightly warm (and not much at that).
At the same time I replaced both old downstairs radiators for new Stelrad ones.
I thought originally that the TRV on the bathroom was faulty but couldnt explain the fact the hallway radiator used to be fine before the new one although it looked past its best hence the replacements.
So today I took both the suspect radiators off, flushed them through a number of times, some rubbish came out but they seemed to fill and flow ok under pressure from a garden hose so both radiators I think are fine.
But when we opened the valves on the radiators, the TRV on the inlet to the bathroom radiator dribbled, while the return valve flowed freely with water.
Same on the hallway radiator, the inlet valve (non-TRV) dribbled while the return valve flowed fine.
So we risked taking the TRV off although looking inside the valve seemed to operate fine. With the TRV off the pipe dripped, nothing more grrrrr.
So looks like I have blocked pipes. I drained down and flushed through the system a few times with the radiators back on, but noticed that water was not free flowing like it had been in the past when I had drained down.
The system is a thermal store btw. Open system with F/E tank above the main tank in the airing cupboard. 2 pumps, one to the conventional boiler to the tank and one to the radiator circuit to the tank.
So after my Dad kindly took a trip to B&Q while I was messing around for some Sentinel X400 (last hope now, before I either get someone to powerflush or some expert in).
So put that in and opened all the valves and lockshields fully with the pump on full speed after the tank was up to temp and same so far, 3 radiators blistering hot, the hallway and bathroom actually stone cold now.
I tried closing the 3 good radiators off for a while but no joy on that either, the other 2 just dont want to play.
Any one got any other ideas?
Thanks very much.
Thanks very much.
