hi. okay ive fit my own bathroom a few months ago. now the hot water tap on the sink will suddenly thump noise and stop or sometimes runs a little but with alot of noise ? now the problem is the shower ive fitted ( mira thermostatic valve) type that runs direct from c/h. runs from the same pipe work as the sink,the shower is fine . so am i correct in assuming its the cheap tap that come with the budget sink .
the hotwater pipe (15mm) runs along up to shower with a "t" branching off to the sink. cold is okay just the hot tap?
someone told me its air trapped in the pipes, but id assume it would apply to shower as well if that was the case ?
thanks for any advice.
