tight tap handle
4 Jan 2009
Leicestershire
I wanted to change a washer on a kitchen mixer tap that is dripping, cold tap, but I cannot get the handle off. The hot side comes off fine. We have had to twist the tap quite hard for some time in order to try and reduce the drip. Have tried gently to lever it from the bottom but did not like to force it too hard. Also sprayed some silicone sray in but still no joy. I have had the handle off in the past to clean the muck that seems to accumulate inside. The tap is 22 yrs old. Anybody any ideas how I can get the handle off?
I have done lots of grunting to no avail!!
You said you tried gently in post #1 so I said try harder. Now you say you`ve done lots of grunting! :confused:
Sometimes I despair at posters here. :mad:
Try pouring boiling hot water over the tap handle. A little expansion with the heat very often works.
