Tiling an Uneven room
29 Dec 2009
Ontario
I am currently getting ready to lay ceramic tile in a Mudroom approx 6feet by 3feet, my problem is, is that the room was built uneven, almost like one of the walls is on a bit of an angle, what would be the best way to lay my tile, as this is my first time ever doing this.
Thank You
Rob
6ftx3ft what type of room is it?
centre the floor (lenght &width)
then mark floor at these points, floor should be quartered.
then dry lay your tiles from centre points to see what size of cut you will have at the walls and door threshold.
then if wall running out badly, swing your centre point accordinly.
