tiling on new plastered walls
14 Dec 2004
How long should you leave it between having room skimmed and tiling on to the walls, is it the same rule as for painting or do you need leave it longer?
More or less & you should be OK after 14 days but what size/weight/type tiles are you laying? What room is it?
Plastering/re-plastering is not always a good idea if your tiling as it reduces permissible tile weight which can be a problem if you’re planning on the modern trend for large format tiles :!:
