tiling on tile - what adhesive?
10 Apr 2009
I'm goingnto be tiling onto tiles which are well fitted, sound and secure and the homeowner does not want them removed. However never done this before and wouldnt usually recommend it. But as they are insisting doing it this way, can someone recommend a tile adhesive suitable for tiling onto tile?
make sure they are clean and dry with no soapscum etc on em, then use a good quality add - i'd usually push granfix multifix, some others prefer bal.
And dont prime - it wont soak in so your wasting your time.
also make sure you have covered your a**e properly as if the old tiles come off so will the new ones (i know you knew that). also in most cases tile on tile will blow the max weight for fixing. like i say, make sure you have warned etc pref in writing!
