I'm about to lay ceramic tiles in a kitchen and I need some advice. I've read the stickys however i'm still unsure of a few things.
I want to lay ceramic tiles on a floor having wooden floorboards (6 sq m) that adjoins an extension having a concrete floor (5 sq m). The floorboards have a (not insignificant) slope (at least 20mm top-bottom) away from the concrete-wood join. Also, at the join, the floorboards are raised above the concrete by approx. 5mm. The concrete is level throughout.
Should I:
Screed the whole concrete floor to the level of the top of the floorboards then ply the floorboards first then prime + screed to the level of the top of the floorboards?
My questions/concerns are:
Using levelling compound with the floorboards' large slope could be expensive. Is there an alternative method of filling to the highest level?
Is filling to the top level of the floorboards the best approach? What are the alternatives, if any?
Would a plywood thickness of 6mm be sufficient for covering the floorboards?
I would be grateful for any advice anyone is able to give.
Should I:
