Right,
I have removed a small section of plasterboard to have a look in the timber frame of our house and I basically have a 4" void and the only insulation currently in the walls is a vabour barrier backed 1" (at a guess) roll that is fixed to the external side of the stud frame and then it has battens and hung tiles fixed to it.
The idea is to fix another 2" of studwork to the inside skin of the timber frame giving a total insulatable (is that a word?) space of 6".
I was originally going to use quilt but have the problem of the vertical sagging to get over. So I am now thinking along the lines of 6" of Celotex cut tightly between all the external studwork.
I have a roll of vapour barrier paper available to use if anyone would reccommend it and would anyone also think it is worthwhile using some extra foil insulation rolls between the studs and plasterboard?
Or even polystyrene backed plasterboard?
The aim is to achieve the highest possible insulation value that I can and losing 2.5" of room space in the process is not an issue.
Any input is greatlt appreciated, especially as I aim to start removing the existing plasterboard in the next couple of days.
Thanks.
Thanks.
