We need to get retrospective building regs approval and our cloakroom (just toilet and basin). Currently it has a bog standard fan that is controlled with the light switch cord.
We need to replace this with a timed one to meet the regs.
Looking on the net it seems timed extractor fans need 3 core and need to be connected to a 3 pole isolator switch. Out current setup just has fan connected by 2 core to a junction box with the lighting circuit, light switch and light.
I've been looking at wiring diagrams but not too sure. Is it ok to remove the 2 core from the junction box, connect a 3 core from the junction box to a 3 pole isolator switch and then have the isolator switch hooked up to a new timed fan?
If so, as it is only a cloakroom, I believe it would be OK to fit the isolator switch inside the toilet just above the door (quite near the light switch and fan).
