Timer
  • Thread starter Thread starter oompah
  • Start date Start date
O
oompah
Me gas boiler as packed up waiting for a new one,so i have to use the imersion for hot water rather than leaving it on all the time and forgetting to turn it on or off is there a timer i can fit to control when it comes on.
Chances are there is a thermostat on t'immersian heater element.
Timers are certainally available, don't try to use a plug in one :shock:
Do you have one element, or a 'megaflow' type cylinder with 2 elements, and are you using economy 7 for the supply to your imersion?
This will probably do you, but do please reply with more info.
http://www.toolstation.com/?r=f&feature=21022
Only got the one element and have not got economy seven.The immersion has got a thermostat just a little concerned that with being at work all day the thermostat could stick and fill the house with hot water and steam.If i got the above timer does it come under part p to have it wired in?
Or cause a fire, who knows, I can see you want to err on the side of caution - good on you.
The timer that I linked for you will be suitable (I doubt your immersion element is over 16A)
More sophisticated ones are available, but I get the feeling your just after cheap and cheerfull to get you through till your boiler gets fixed/replaced.
As long as it does the job,thanks for the reply,just one more thing does it come under part p to wire it in?
you might find the digital timers a bit fiddly to set, in which case you can get one with a round "clock face" and settable tappets, which is very intuitive, for about the same price.
