- Joined
- 17 May 2012
- Messages
- 11,316
- Reaction score
- 978
- Country
I have 18mm green chipboard on my bathroom floor. Only 2 joins (room is 2.3m wide) and all pretty flat and smooth. Friend (a plumber and bathroom fitter) said that I just need to tape over the joins to avoid risk of lines appearing in vinyl sheet.
Previously, floor fitters have suggested putting ply down.
Just been quoted £60 for vinyl, £40 to fit, plus £80 if i want to ply.
Do I need ply? One suggestion was that if the floor needed to come up, it's easier to remove the ply than tear glued vinyl off chipboard (could cause damage). So that makes some sense.
How is ply fitted normally? Tempted to do this part myself if I'm going to save some of that £80. Is is screwed? I guess not glued, as that would then have the same problem when removing ...
