I have a set of long-handled Rothenberger
fan orifice/pipe stretchers which go 12 up to 28mm iirc.
If your pipe is hard, it splits.
From plumbing up the first block of flats I had donkeys years ago, on, I have a reasonable proficiency with soldering pipes.
But I haven't done it for a while so I'd use solder ring fittings.
They're easier to use under a floor, and not muck up. Some architects/building designers insist on them because they're more reliable. A bag of 5 from
Wickes costs nearly nothing.
Cut debur and clean your pipes, clean inside the new fittings with a wire brush.
Laco Flux the pipes, not the fittings. Insert both pipes into fittings, wipe of excess flux (makes it neater) heat the fitting and pipes evenly until you see the solder at the end of the fitting. Done. Wipe with damp cloth when cooler. Check any hidden fitting end with a mirror.
As you're a beginner, have some solder handy in case you do muck it up, but it's absolutely not necessary.
