I have just moved into a large house with a pumped central heating system, the boiler being a Potterton Kingfisher 2 which i believe is about 12 years old.
They have *******ised the mechanical Landis & Gyre timer so that to work the hot water you have to have both hot water & central heating selected. To switch the heating on, there is a seperate toggle switch on a home made box which effectively gives you H/w or H/w & C/H.
There seems to be no T-valve and a pump for each heating circuit. Both circuits disappear into the boiler, so i presume the boiler is designed this way.
There is a room stat as well as a h/w cylinder stat. I have added TRVs to the rads.
All works well, except that the timer is cumberome and allows only two time periods which have to be the same very day and have to be the same for H/W & C/H. The override is basically off/on until the next time period and in a house this size it is expensive to let it run.
Q1 Is the set up i describe normal - i.e. to have two pumps.
Q2 Is it possible to get an electronic programmer to control a 2 pump system?
Q3 Is it easy to do and under the wiring rules, are we amateurs allowed to do it?
Q4 If the answer to the above is yes, how about being able to add extra valves to split upstairs & downstairs into two zones, or am i pushing my luck?
Any help gratefully receieved.
Tim
Tim
