My toilet cistern is perpetually overfilling and feeding into the overflow causing a constant drip (at best (flood at worst))...
The toilet is fed from the main tank in the attic via a 15mm pipe which is also linked to washbasin (1st) then the washing machine (3rd).
The system suffers from seriously low pressure (about a 3 inch spurt of water if the pipe is left exposed).
The cistern is filled through a vertical fill valve (fluidmaster 440). I have recently cleaned the valve and replaced the diaphragm with a (red) ultra low pressure one (at the advice of a plumber). This seemed to stop the problem (it slowly stopped happening after a couple of weeks), however, having replaced our washing machine (the fill valve failed), the toilet has started overflowing again. Could this be something to do with the drag of water overloading the valve???
Should I try going back to an old-fashioned ball-cock system?
If anyone has any suggestions then they'd be greatly appreciated - Please help!!!!
