Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have got a cistern with a push button flush,the problem is that when the toilet is flushed the cistern fills up and at the end of the filling process a loud thump is heard thro the pipework,what can I do to cure this.
regards
Try adjusting your float or changing washer. It sounds like your float is cutting incoming water off rather abruptly.
May need a new float valve.
Take off cistern lid and listen to where the noise is coming from.
