Toilet Filter
How do I clean the filter on a Roca dual flush toilet? I have been told this will stop water continually leaking into the toilet bowl. Thanks
You need to replace the syphon washer located at the base of the syphon. Remove flush buttons, unscrew chrome tube and take off cistern cover. Unscrew syphon anti clockwise and remove from housing. Using pliers, remove white plastic cap and take off washer. Fit washer and refit syphon using reverse of above
i would say its been done in the 3 yrs since he asked.
I've had ths recurrent problem. It's called'phantom flushing'. The water leaks into the bowl and thenn when the cistern empties past a certtain point, the cistern fills up again. rather disconcerting when you believe yourself o be home alone.
i live in a hard water area (northampton) and the rubber washer seems to need sorting every 18 months or so.
What you can do s to give it a good scrub with a nail brush to remove the 'gunge' or you can turn it over.
it's true, that ideally youshould remove the plastic fitting to remve the washer, but I have found that it can be removed and replaced by 'stretching'.
i suggest you buy a number of replacements...i don't think the problem will go away.
