Toilet Flush
10 Oct 2007
Kent
Hi There
I need help with leaking water from overflow. The water level in the toilet raises above 6 L. What do I need to adjust in the ball valve? To stop water coming up to 6L.
The water from the main water tank in the loft is leaking in the overflow as well. What do I need to do?
Both of above happening when water not in use early morning and late at night.
Please help my water bill is going up and wasting lots of valuable water.
Cheers :(
Assuming you have a float with a ball attached ......
There should be a screw which pushes onto a button when the float is raised that cuts the water off. Unscrewing it cuts the water off quicker.
The loft one needs to have its washer renewed or simply bending the metal arm down to cut off water quicker.
Have a play with them and you will see how they work. :D
