Toilet leak Problem
deanfleet said:
surely a foam easher is a foam washer
No - there are different shapes, and different thicknesses, and different materials that compress by different proportions.
I carn't see that there is a problem with the donghnut washer as the op said that he put some toilet paper there at night and when he got up it was wet. So unless someone used the toilet in the night it carnt be the doughnut. I would think its the either the float valve (where it enters the bottom of the cisten) or if its the sort of cistern where the close cuple bolts fasern through the bottom of the cistern and not a plate.[/quote]
hey guys,
Job done went to focus and got a new washer, its a big thick rubber one and cost £1.99.
It was indeed the doughnut washer that was leaking and the reason it was leaking beacuse for some strange reason the inner part of the ring had been masacared, it looked as if someone had got a knife and tried to cut the inner ring to make it wider!! Botched job by the looks of things!!
anyways i put the new rubber ring in and its been left for a couple of hours with several test flushes in between and now its dry behind the toilet, there is no water coming from anywhere.
Ill post a photo of the botched rubber ring the plumber put on.
Your palm reveals that you will meet a tall dark stranger, on a windswept moor, on the night of a full moon, whose eyes will appear as deep as the universe is wide, whose breath will feel as cold as the keenest Arctic wind, whose deep voice would make thunder as if it were the shrillest falsetto, whose footstep would... <that's enough of that, Ed.>
Either that or you once done some manual labour innit.
