toilet leak
17 Jul 2007
Kent
The water pipe which supplies the water from the cistern to the bowl has a crack in it.It is a hidden cystern (not hidden yet).
The pipe has 2 sections one which goes down the wall and the other connects that pipe to the bowl.
It is the second pipe which has split at the join. Am i better off replacing the pipe or is there something i can do to fix the pipe?
hope this makes sense?
Is it the curved plastic white pipe that bends into the loo pan :?:
If so you can replace it and the flush cone for about £6
:D
Replace with new pipe. You don't want to have a bodge that may leak and cause water damage where you cannot see it.
