The toilet upstairs is flushing all ok, problem is when you put even one slight bit of paper in it, flush it and it wont go down. (the water goes down but not the paper and it doesnt fill this pan as if there is a blockage)
I have put a toilet auger down the pan and no blockage, been in loft to the vent pipe and done the same and still no blockage.
Bath and sink drain ok and downstairs toilet is ok also.
It seems when you flush the toilet the water makes a swirling motion all around the pan if you understand, rather than swirl to the front part, dunno if this is making sense to you.
Ok so can anyone suggest anything?? what can the problem be.
The toilet used to work fine.
