toilet waste soil pipe
10 Mar 2013
Durham
hi all wanting to modernise the downstairs toilet want to turn it 90 degrees its on an external wall into the garage
so turn toilet dig up garage floor and run new soil pipe and break into manhole 3 metres away simple
now do I need building regs or a notice
also whilst im on if I branch the toilet into a vertical soil pipe can I connect the upstairs toilet into the same pipe its approx. 8ft from the proposed new soil pipe
many thanks
I believe that any works to drainage are notifiable; there's a raft of stuff you need to comply with in Document H of the building regs and the local authority will want to ensure that works do not create a hazard to health
Two toilets can each be directly connected to one vertical vent stack and won't interfere (though there are regs to follow in relation to the vertical separation of the connecting branches when doing this), but if two toilets were to be connected on one horizontal pipe suitable vents would have to be installed between the toilets, otherwise the flushing of one could siphon all the water out of the other toilet, resulting in it venting sewer gases into the property. Ask your LABC; theyre there to ensure a job gets done properly, rather than be a thorn in your side
