Tool for tightening nut securing monobloc taps?
3 Sep 2007
Manchester
My joiner has just fitted new worktops and sink, leaving me (clueless) to re-fit the existing taps.
I can't work out how to tighten the nut that secures the washer securing the monobloc into position in it's hole.
There's no space for a spanner, and a socket won't work because the threaded bar is far too long.
Is there a special tool for this job?
Many thanks.
Try a metal spacer tube to effectively reduce the length of the threaded section. this will allow you to get a box spanner on it.
A piece of small bore c/h pipe might do it.
Yes there are a special set of box spanners, for want of a better description, that are used to tighten this.
Plumb Center sell them, so no doubt other merchants do as well.
Following your good advice I did a google search on monobloc box spanners and have identified the tool I need.
Thanks.
Love that idea. :D
