Toupret wood filler - screw heads query
27 Jul 2006
I have recently fitted some skirting board and needed to fix with some screws
Can anyone confirm please whether the screw heads need to be treated prior to filling the holes with Toupret wood filler ?
I can’t see anything in the instructions however I have seen on other forums that other fillers advise using an oil based paint to paint the screw heads so I was wondering whether this practice was needed with Toupret
TIA
Filler sticks better to the undercoat. So, on refurbishment, sand the wood. Wash over it as it must be clean. Apply undercoat to wood and to the screw heads and holes. Now the filler has a good surface to stick to and any caulk mastic.
To answer: It's better to prime, but sometimes there isn't the need or time, as we need to crack on with job
Cheers mate
It was much more important in the days when we used plain steel screws and nails (not BZP) as rust stain would come through.
For skirting, I would countersink the screws just a fraction below the surface first, so the filler has something to sit in rather than a thin skim over a proud head. If the screws are coated, you can usually fill straight over them once the surface is clean and dust-free, but if they are plain steel it is worth giving just the heads a dab of oil-based primer or undercoat and letting it dry fully first — that is what stops a rust mark showing through later. For deeper holes, fill in two thin layers rather than one thick one, let the first dry before the second, then slightly overfill the last layer and sand it flush when dry. A quick spot-prime over the filled area before your topcoat also helps it blend in and stops the filler flashing through the finish.
