Have just bought a ladder type towel radiator for the bathroom. It's designed to be plumbed in to a wet system and can also take an electric element for use when the heating is off.
Don't have a wet system here, so just plan to use it with the element. It just occurred to me 'though, that I will be sealing it completely, so there will be nowhere for expanding fluid to go when it heats up, as there would be if it were plumbed into a wet system. Will this be a problem? I'm guessing not as water doesn't expand too much and you can get sealed in only electric rails that are similar, but just thought I'd better check here. Sometimes I think the sealed units are filled with oil. Maybe this is to prevent corrosion or maybe oil has a lower expansion coefficient?
