Toyota Bonnet badge removal
15 Nov 2005
South
Cook Islands
I am having some scratches and chips touched up on my Carina, thought I would get a better finish if I took the bonnet logo off first, but there are no nuts or bolts visible on the underside (it is a closed box section).
Is it likely to pull or lever off?
It will slowly why dont you use a heat gun NOT , use a hairdryer on low warm it up and it will come off , you will find it foam ripping off back , just clean it up and put new stuff on after, unless its other version of stuck on but should come off .DONT FORCE.
