    Dismiss Notice
Transfer of ownership of private sewers
Discussion in 'Plumbing and Central Heating' started by Adrian80, 8 Aug 2011.
  1. Adrian80
    Adrian80
    8 Jun 2008
    439
    Thanks Received:
    11
    Bristol
    Country:
    Hi All,
    I wondered if you guys had any opinions, on this stealth transfer of ownership of lateral drains.
    http://www.wessexwater.co.uk/water-and-sewerage/threecol.aspx?id=4570
    their official pdf leaflet.
    http://www.wessexwater.co.uk/workarea/linkit.aspx?linkidentifier=id&itemid=7414
    I am planning on appealing the transfer as i am planning on building an extension and can only see this causing problems.
    Very interested in your comments, and or suggestions for lines of attack or successful attack against the further encroaching state..
    Cheers
    A
  2. Sponsored Links
  3. Geps
    Geps
    14 Dec 2010
    197
    Thanks Received:
    11
    Birmingham
    Country:
    As someone who has 2 public drains and a manhole within my property I say thanks!
    Can't see how this is a bad thing?
  4. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,342
    Kent
    Country:
    About time it was done.
    It only affects drains which carries effluent from more than one property. So it saves arguments between neighbours about getting work done if there is a blockage or part of the drain collapses. It also saves arguments over how the costs should be shared.
    My son is about to move into a four year old house where a main sewer runs underneath the house. I can't begin to imagine the costs involved if it collapsed or sprung a leak. Fortunately that will no longer be his problem.
    If you want to build over a shared drain you already have to get special permission.
    My son currently lives in a house where the conservatory was built over a lateral drain. The vendors could not produce any documentation to show that the necessary approvals had been obtained, so the solicitor insisted that the vendors purchase a £100k indemnity policy to cover him against any claim.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
