i've got a problem with no hot water being drawn from the cylinder, i've been told i might have trapped air in the coil and i need to remove it. how would i do this ?
sorry when you turn the hot taps on cold water comes out, the rad's are all working find and i've checked for trapped air, it's a conventional system...
when i turn the hot taps on cold water comes out... the ch and hw have been on for about 3 hours now... the radiators are working ok... and cold water comes out the cold taps...
there's a pipe coming out of the middle of the cylinder which appears to have a airvent on it ? should i open that ? (it appears to be the same as on a radiator)
