trevi boost..exposed.
JPC
10 Aug 2004
Leicester
hi guys...
Has anyone fitted a Trevi Boost shower..you know, the mains cold and gravity hot ones.
Q - are the hot and cold pipes fed from the rear to the shower mixer and does the hose screw into the unit...or a separate fitting ??
what would make life easier is a trevi boost (for better performance shower) bath taps...no chopping tiles out...just change the taps and hang the rail and shower head!!! but i havent seen such a product
Yes.
The elbows can be oriented to take pipework from above, or below, or behind, or in front (if you really want to).
Yes.
You don't need to chop tiles out to fit a Trevi Boost.
softus...did the shower perform well ?
i imagine i'll have to to bury the pipework...or can the mixer work by "bluetooth" ? :wink:
as usual customer doesnt want the pipes showing...and i dont blame them.
softus...as you know there are various ways round a mains cold gravity hot....which is simplest and cheapest in you opinion ?
i have had endless folk asking me for showers over the bath with said circs and they dont like the proces i quote......as you know shower mixer, pump, new or additional cwst, labour all adds up.
in the past i have fitted presure equalising valves...to shower only pipework and told them it wont be a power shower...and indeed it isn't.
i have also thought of putting a single pump on the hot only and then onto the PEV.
Curiosly i when to a house the other week and they had a 2 tapings near the top of the cylinder...mains in the bottom>>>>>>warms up>>>>hot out the top (thermal store effect) then then onto a thermostatic mixer...worked well and might try it sometime
i think a simple bath tap with venturi workings inside for a shower would sell like hot cakes
Regarding performance, i have a Trevi Boost and it's simply not up to the job for my situation. In fairness the system appears to perform at roughly the manufacturer's spec - I have 0 positive head on the hot and poor mains pressure!
Even so, if you're after a "good" shower, the only situation I'd think a venturi unit will fit the bill is when installing a downstairs shower in a typical 2up-2down with tank in the loft - i.e. a reasonable head of water on the hot cylinder and the benefit of better mains pressure down at ground floor level.
You have the wrong product then.
That's far too indeterminate to be of much help.
The pressure advantage of downstairs vs. upstairs is merely 0.5 bar, which is far less than the difference between poor mains pressure and excellent mains pressure.
Regarding the OP's situation, it would be wise to measure the mains pressure before spending money.
but did it work well softus....the one you installed....
was it half way to a power shower ?
if so i will try one on the next job i do..assuming a decent incoming pressure
Yes.
There is an 'exposed' edition of the boost. Not quite bluetooth, but no chasing either.
Oh. Cancel previous comment then. Chasing/burying it is.
Simplest is not the same as cheapest. My preference would always be balanced supplies, whether gravity, pumped or mains, so that you're not relying on balancing valves, or venturi valves, or check valves to keep on working.
Cheapest depends on whether or not you can run a new cold supply from a storage cistern, and whether or not you have a cheap plastic-bodied low-flow shower pump for occasional use, or a full-blown brass-bodied stonker that can pump all day without needing to be cooled down.
I'm sorry, but I didn't understand very much of that sentence - what are "circs" and what is "proces"?
Well, I recommend keeping it simple, and buying a valve that you know you can get spares for.
I can but suggest that you don't tell people that a non power shower is a power shower.
I've seen that work, both with and without the PEV.
Possibly, but you don't need the mixing function of the venturi shower valve when drawing a bath, so in a sense it's a strange idea for a product.
