My dishwasher is not taking in water when started. It powers up OK and there is a sort of thrumming noise from the inlet valve - I think - but no water goes in.
I've had a search and found a couple of old threads which make me think that the valve is locked out. So far I have taken off the inlet hose and reconnected it as suggested in an earlier thread but no joy.
Next I took apart and cleaned out all the bits that are accessible from the inside of the machine and although they were a bit grotty this has not helped either. Then I tipped it on it's back and took off and blew through as many hoses as I could manage particularly the little ones which go up through the plastic tray into the U-tubes. One of these is connected to the inlet valve and I presume it is a sensor of some kind.
One other point is that the tank under the salt filler was full to the brim and so I suspect a blockage in there or in one of the hoses attached to it but it seems like a bit of a job to get it out.
Can anyone help please?
Dave
Dave
