Tritan T80 electric shower, leaking a bit
24 Aug 2009
Birmingham
Another quick query I have - my electric shower, which is Triton t80, oldish but still decent, water was dripping from the bottom of the unit every few days. I took the cover off and notice when the shower is turned on at the dial (not when the cord is pulled) and the pressure switch i believe it is allows water through, water splashes/jumps out of this area, a little bit every time this is turned on. I believe it builds up and after a few showers, leaks from the unit.
Is this replaceable and easy to do or is it new shower time?
Thanks for your help again :)
thats the top of the stabiliser valve it wears around the plunger.
can be repaired.
hi secon services. thank you for helping me. i was thinking maybe it is a diaphragm or something inside the valve that has worn/perished over the years. do i need to buy a whole new stabiliser valve? is this easy to get hold off for me shower as it is oldish, and if so, will it be hard to replace, i am not a bad diyer :)
ok thanks secon, i will order 1 up now. (hope they have 1 in stock and can deliver by the weekend possibly)...
one last question: is it hard to remove the old one??
give them a ring and order it.
useally get my orders next day.
bit of fiddling about but not a hard job.
