hi first time post on here so here goes
i moved into my house a little over a year ago, already fitted was a Triton Hawaii 2 which has worked perfectly fine in the last year, however about a fortnight ago the temperature dropped so i'm thinking new shower time, but after having a look online i found that a common thing is the TCO, So i replaced it with a brand new one from the shower doctor, an easy cheap fix i thought, BUT still no different, i thought it must be the drop in the water temp due to the weather, but then i remembered last winter it was working fine all i had to do was turn the dial up a little which was all good, then i looked online again and found it could be high water pressure so i turned the mains down to reduce it but still no different. To get it any where near hot it has to be turned up to the max which is not powerful enough to have a shower.
I'm baffled now can anyone help me please please please
