Hi all any advice appreciated I fitted two radiators both with trv,s rad not getting hot after investigating I have found one trv is on the flow on one rad but on the return on the other rad question is would this stop rads from getting hot thanks in advance
If it worked okay before. Make sure valves are fully open, turn heating on and turn off the radiators that are Working. You should hear a gurgle and then they should work.
If they didn't work before. Possible blockage.
Jeff
Both were new rads when fitted had to extend pipe work to fit extra rad so most of pie work is new I have taken both trv heads of and one rad is getting hot now one pipe is hot one is cold on both rads as if it's not returning
