Can any one advise whether you can fit a TRV on a heat dump radiator.
The system is an open vented system and the radiator which needs replacing is in the bathroom. It is not on the heating curcuit but is fed from the hot water cyclinder and gets hot when the domestic hot water is on but the heating is not.
The reason the rad needs changing is that it has become choked. The entry is at the top and the return is from the bottom.
I have not come across one set up like this before and think that the water must circulate via natural convection to and from the water in the domestic hot water tank. Sort of like a heat dump radiator. Is this right? If not how does the water circulate?
On the radiator front I want to fit a new rad with a TRV with the entry at the bottom. Will this set up work if it is unpumped heat dump?
Not inspected the rest of the system yet, but if there is muck in the rad on a hot water circuit, then surley the water cyclinder and header will be full of muck as well. Any advice.
Cheers for any help.
