Hi, I run an electric shower which is supplied by an 15mm pipe from a link in the property.
The property has adequate pressure but low flow due to the house being fed from an old lead pipe which can/will not be changed for other reasons at this time.
The shower works OK just! would this improve if I pulled a 22mm pipe as close from the supply as possible direct to the shower??
My other choice was running some form of hot supply of a tank somehow but the property has a worcester 30si combi boiler and no tank. Any thoughts would be great thank you.
