Trying to make out if this is good electric rates or not???. Certainly different.
15 Feb 2009
Norfolkshire
Just been looking around for a better electric deal as my lecy has gone up 19% off-peak & 39.7% peak. Now most households tend to use a lot of electric between 3pm & 7:30pm & of course that's why the lecy companies have their high rates at these times, including the one below. But would be interesting to see if you could make it work in your favour.?? Its certainly different way of pricing, & i like differant. 100 green.com
100 green.com
100 green.com
That’s certainly an unusual pricing structure! I’d work out the cost using your actual half-hourly or hourly consumption rather than just comparing the headline rates. If you can shift the washing machine, dishwasher and EV charging (if applicable) away from the peak period, it might work out well, but the standing charge and the expensive 3pm–7:30pm window could easily wipe out the savings. Have you compared the rates against your current tariff using a typical month’s usage? That should give you a much clearer idea of whether it’s worth switching.
Seems too good to be true. I’ve just got a quote from them for medium usuage (which they have estimated lower than my actual use) and it’s £159 a month. Recently changed to British Gas and as I said, I gave them my actual use. My monthly standing order with them is £105 per month.
From around 10 am to midnight my use is near to zero at the moment, I rely on off-peak however for the bad days. The export at 12p/kWh I get at the moment is the make and break point. And the main thing is how ones inverter can be programmed.
So at 8.21p/kWh off-peak, and 12p/kWh export I can set to charge batteries to full, and even if no space in batteries during the day for solar, I am still gaining.
OK if batteries run out 30.74p/kWh until 00:30, but I would hope this time of year they will not run out very often.
So last month bill was just under £6, this month already spend around the same, so looking at 2025 no details for before April but £64.48 for April onwards is not too bad. This year can't get software to show price, in kWh it is -951,075 kWh.
Jan to April this year cost £114.37 so Annually the bill around £180. It will be more now as export dropped from 15p to 12p but to my mind the 19:30 to 22:30 at 15p/kWh would be an advantage, but the 03:00 to 06:00 is too late most days, and if export is less the 15p/kWh one would need to be very careful not to charge up the batteries too much.
So if no batteries or solar, it would require a lot of careful use, and I would say it would be very good for heat pump users.
With solar only, one is in the lap of the gods, as you can't predict when you will get solar.
With solar and batteries, it will depend on battery size, if we still had 3.2 kWh battery it may have helped us, but with 6.4 kWh it is unlikely to help.
Do you know when you use the most electricity each day? If you’re out at work during the week you’ll hardly save anything during the day and get penalised when cooking your dinner
