I know it should be simple to do but I just can't seem to get the new drum paddle to slot in. I get one side aligned but can't get the other side in. There must be a trick to getting both to slot in, so any help please before I end up going mad!!!
the lifter goes in one way but ther are 2 versions one has clips on the outer edge ,one hasnt .place lifter over hole in drum so the clips line up push down then push towards the door so it clips into place you should hear the clip as it goes in
