Hi all,
I'm trying to fault find on my CH system. As far as I can work out it is an open vent fully pumped system. The hot water tank is a double input Hercal boiler. On one side of the boiler, the side that has the three position motorized valve there is an output pipe quite low down the tank. This output pipe has a single valve/stop cock, what does this do?
After draining and refilling the system at the beginning of the week I had no heat to the radiators until I moved the valve fully to the right. Once the radiators were warming up I thought this was correct so left it as it was. This resulted in no hot water. Turning the wheel to the left this seemed to give both heating and hot water.
Having to drain again today, due to adding a clearing additive last time, I can get all but one radiator to heat up, but I need to move this valve to kick everything into operation.
Sorry about the length of this,
What does the valve do?
What position should it be in?
What can I do about this cold radiator?
View media item 42671
Thanks in advance
GTXZAG
Thanks in advance
GTXZAG
