I am looking to get a quote for someone to relocate a cooker control unit and install a cooker connection point, which seems fairly staightforward, but I have a query regarding the earth cables sizes in my flat.
The electric were installed in 1998 and have an earth cable (poss 6 or 10mm difficult to tell) from the CU to the adjacent gas meter. There is also a similar size cable going to the earth rod under the kitchen floor. This then goes from earth rod to all the combi boiler pipes and then to the bathroom where it connects metal pipes under the bath before going to the water stop cock supply pipes (under bath).
When I got a quote from British Gas they advised I needed to upgrade the earthing to 16mm to the earth rod and 10mm for all else and I gather this is as per the regs.
Question is - do I actually need to do this for safety and the change to the cooker unit control? and were cable sizes smaller for earths in 1998? - Also if I don;t have it done now, will it be a problem in the future if I ever sell flat or rent it out and it is picked up on a periodic inspection report.
Would be interested in knowing what are the real implications for having lower than standard c.s.a of the earth cable and main bonds?
Many thanks
Many thanks
