It depends on the EFLI, it can sometimes be as high as 1666 ohms, in which case a 30mA RCD must be used, to keep the touch voltage down below 50 volts.
The normal way to do it would be to fit a 100mA time delayed RCD as the main switch, and then an additional standard 30mA RCD / RCBO to any circuits which require additional protection (such as socket circuits likely to supply equipment outside)
barely and not allowed at all if you have mains powered fire alarms (possibbly just ones without battery backup i'm not sure on the details of fire alarm regs.
