My aunts boiler has been playing up recently so went round today too see if I could fix it
The problem is is that when they open hot tap, boiler fires up, goes upto about 85 deg c, water comes through hot, gas shuts off, water goes warmish, gas back on, water hot, so on and so on.
Central Heating works fine
I had a pcb on the van for this boiler (even though I was convinced it would be thermistors). Changed the board and still the same problem
Looking at the boiler, I could see 2 ntc's (one on the flow and one on the dhw flow or return), is this correct. Anyway, I thought that by unplugging either ntc would produce an error code on the boiler. I unplugged the ntc on the dhw side, and the boiler still functioned. I then plugged the ntc back in and unplugged the ntc on the flow, which then brought up the error code on the boiler.
Going on what Ive said, do you think the problem lies with either ntc? Why didnt I get an error code when unplugging the ntc on the dhw side?
