Didn't go into the detail of BC cost as I was merely pointing out the missunderstanding/misconception regarding part P: I did, however, say it would have to be tested & certified by a qualified person before BC would issue a completion cert. I do agree it would be far easier (& probably cheaper) on such a small job to get a part P in to do the lot
If it’s an internal stud wall that's different! You can run cables within these as long as you stay within the ‘safe zones’. Cables outside the safe zones in any wall or partition must be at least 50mm below the surface or be protected by an earthed metal covering or enclosure to provide mechanical protection; steel capping is not considered suitable.
