Turning off immersion tank....
9 Jan 2014
Berkshire
This is doing my nut in so I'm hoping someone can help before calling the plumber in:
I need to shut off the hot water pipe in my downstairs toilet but there's no stop valve so how do I shut off my immersion tank so that no hot water reaches the pipe below?
My immersion tank supplies all my hot water, i.e no combo boiler, but I just can't find any kind of stop valve coming from it.
Any ideas? I can supply pics if needs be...
Cheers in advance
Is there a gate valve/isolation valve on the supply pipe from the cold water storage tank to the cylinder ?
if not you can bung the supply pipe.
Hiya,
Yeh I think so. there's a valve on a cold pipe from the attic heading straight into the base of the immersion tank with a big red handle...
I'm presuming now that If i turn that off, drain the immersion tank, should be good to go?....
Cheers
Yes turn that off. if poss they are useally jammed solid cause they don't get used.
It won't drain the cylinder it'll just stop water going in so water can't come out.
Run the tap it'll just empty whats in the pipe take a few seconds if the flow don't stop fully when the gate valves closed it's more likley not shutting fully.
They get clogged with scale etc and don't always close fully.
Also make sure the immersion heaters are switched off while this valve is closed
