Hi All,
Novice here.
I have bought a new tap to replace my mum's faulty kitchen tap.
There is a mains tap which I have turned off and this stops the cold water pretty much instantly.
The hot water still runs.
In her hot-press there is a big tank and there is a red valve that looks something like this.... http://static5.depositphotos.com/1001496/475/i/950/depositphotos_4755028-Red-valve.jpg
Would this stop the hot water? I have turned it right as far as I can. How long would it normally take for the hot water to drain?
My mum is paranoid that if I drain the whole system it will damage the radiators of the central heating system... cause some airlock or something.
We don't have the money to get a plumber to do this, so any advice would be much appreciated.
I'm pretty confident that I can fit the actual tap... just concerned about causing a problem with the central heating or pipes if I don't turn it off/on properly.
Thanks in advance.
Novice here.
Thanks in advance.
