TV bracket, swivel, close to wall
17 Apr 2015
hi
I need to find a TV bracket, needs to swivel at least 45degrees each way, doesnt need to tilt really. TV size won’t be big, twenty something incher.
Main concern is that it keeps TV as close to the wall as possible when not swivelled, as it’ll be in the middle of a room on a pillar, and seen from the side all the time.
Looked at loads online, and seen things like this: https://www.currys.co.uk/gbuk/tv-an...4251-tilt-swivel-tv-bracket-10171250-pdt.html
Which apparently allows it to be about 62mm from the wall, not sure if that can be improved on with a different bracket.
Only ever fitted one of these before and it was a flush/fixed one, so any advice much appreciated. Thanks.
Spot on, thanks. Closer to the wall and cheaper than the one I found.
I have something similar to both those designs, and paid less than a tenner at the time. This is for my son's 22" bedroom TV. The thing is it's not very good.
It sags. A tiny amount of play in the hinges joints translates to about 2 or 3 degrees of tilt on the TV from left to right. That doesn't sound like much, but it's very noticeable.
This was definitely one of those times when I got exactly what I paid for.
Hmm. Yes agree they’re certainly cheap. I’m confident I’ll get a rock solid fixing into the wall as I’ll put noggins in, but yeah if the bracket has play in it then that’s a bit cr@p.
Yep, I got decent fixings in to the noggins too. The bracket is still crap though.
