LG TV Wall Bracket
17 Jun 2010
Sussex
I have an LG 24" TV and want to buy a bracket which swivels and tilts and have no idea what to buy. Can anyone advise the best, I am not keen on the scaffolding type, only want something fairly indiscreet. With the ones I have looked at it seems you have to undo fixings on the back to tilt etc., are there any that you can adjust by turning the TV slightly rather than undoing fittings each time? Many thanks for any help.
TVs now don't weight much Vs old glass plasma TVs.
Just look at the weight guide for brackets.
I just used 6mm bit and red plugs vs anything special to fit if in solid walls. Fitted a few on swivel brackets and all fine.
Oh. If screws are under 3.5mm thick then 5.5m bit with red plug.
Think the scaffold type is overkill. Not seen any like that for years
